LCD display
t.man
i'm trying to send characters to the dispaly but failed, i'm not even sure that the display do initialize.
i'm using KS0066U dased lcd(i.e PC1602F from POWERTIP company). it is a 16 pin display.
my hardware configurations:
LCD------------MCU(ATmega8)
Vss-------------------------->POWER SUPPLY(GND)
Vdd-------------------------->POWER SUPPLY(+5v)
Vo(Contrast Adjust)---------->(120 ohm to GND)
DB7-------------PD7
DB6-------------PD6
DB5-------------PD5
DB4-------------PD4
(DB3-DB0) tied to ground
(PIN 15 & 16 ) not connected
software
main.h
#ifndef MAIN_H
#define MAIN_H
#include <stdio.h>
#include <avr/io.h>
#include <util/delay.h>
#define LCD_DATA_PORT PORTD
#define LCD_DATA_DDR DDRD
//define lcd control port
#define LCD_CTRL_PORT PORTB
#define LCD_CTRL_DDR DDRB
#define LCD_rs 0
#define LCD_rw 1
#define LCD_en 2
// LCD instructions
#define LCD_start() LCD_command(0x20)   /* Send 0x2(0) */
#define LCD_function_set() LCD_command(0x28) /* LCD function set */
#define LCD_display_off() LCD_command(0x08) /* LCD display off*/
#define LCD_display_on() LCD_command(0x0F) /* LCD display on*/
#define LCD_display_clear() LCD_command(0x01)/* Clear display LCD */
#define LCD_mode_set() LCD_command(0x06) /* LCD mode set */
//functions declarations
void LCD_enable();
void LCD_command(unsigned char command);
void LCD_putc(unsigned char ascii);
void LCD_puts(unsigned char *lcd_string);
void LCD_init();
#endif
main.c
#include "main.h"
unsigned char text[] = "AVR Project";
int main()
   LCD_init();
   LCD_puts(text);
void LCD_enable()
    LCD_CTRL_PORT |= (1<<LCD_en);
    _delay_ms(1);
    LCD_CTRL_PORT &= ~(1<<LCD_en);
    LCD_CTRL_PORT &= ~(1<<LCD_rs);
    LCD_DATA_PORT = (command & 0xF0)|(LCD_DATA_PORT & 0x0F);
    LCD_enable();
    LCD_DATA_PORT = (command << 4 & 0xF0)|(LCD_DATA_PORT & 0x0F);
    LCD_enable();
    _delay_ms(1);
    LCD_CTRL_PORT |= (1<<LCD_rs);
    LCD_DATA_PORT = (ascii & 0xF0)|(LCD_DATA_PORT & 0x0F);
    LCD_enable();
    LCD_DATA_PORT = (ascii << 4 & 0xF0)|(LCD_DATA_PORT & 0x0F);
    LCD_enable();
    _delay_ms(1);
   while (*lcd_string)
      LCD_putc(*lcd_string++);
void LCD_init()
   //initialize LCD control lines
   LCD_CTRL_PORT &= ~(1<<LCD_rs);   // RS low
   LCD_CTRL_PORT &= ~(1<<LCD_rw);   // R/W low
   LCD_CTRL_PORT &= ~(1<<LCD_en);   // E low
   // initialize LCD control lines to output
   LCD_CTRL_DDR |= (1<<LCD_rs);
   LCD_CTRL_DDR |= (1<<LCD_rw);
   LCD_CTRL_DDR |= (1<<LCD_en);
   // initialize LCD data port to input
      LCD_DATA_DDR |= 0xF0;// Data on high four bits of port
   _delay_ms(30);
   LCD_start();
   LCD_function_set();
    _delay_us(40);
   LCD_display_off();
   _delay_us(40);
   LCD_display_clear();
   _delay_ms(2);
   LCD_mode_set();
   LCD_display_on();
i need help!
Try tying the lcd's RW pin to ground.... Kinda essential to get it working correctly!!
In your list of connections RS and Enable aren't listed. They need to be connected to PORTB bits 0 and 2 respectively.
sorry not to mention them
RS is connected to PB0
R/W connected to PB1 and
E is connectd to PB2
I just had a look at your code and it is not doing the initialisation correctly.
There is a sequence of actions to get the LCD initialised.
Try changing your init routine to,
void LCD_init()
    _delay_ms(15);		//start of required sequnce
    LCD_command(0x30);
    _delay_ms(5);
    LCD_command(0x30);
    _delay_ms(1);
    LCD_command(0x30);		//end of sequence
   LCD_start();
   LCD_function_set();
    _delay_us(40);
   LCD_display_off();
   _delay_us(40);
   _delay_ms(2);
   LCD_mode_set();
   LCD_display_on();
hi Mike,
Another effect I have seen when the PWRTE has been disabled and the LCD initialising subr is at the start of the program.
Some slower LCD's are still settling from the power up when the init subr is trying to set it up.
The result being the LCD is not initialised
I would suggest the CONFIG PWRT, when using the HD44780 should be enabled and the init subr not placed at the start of the program.
Regards
Hi eric,
The OP is using an AVR and so I don't know if it even has a Power up timer. However, the initial 15mS delay is supposed to take care of that problem. If the OP has a particularly slow power supply then increasing it might be advantageous.
Hi eric,
can power suply have effect on the problem? and how do u increase it?
i'm using a 12VDC plug-pack supplying a LM78L05 regulator.
...Again can unconnected LED backlight power suply pins on LCD contribute to my problem...if yes how can i connect them.
what happens now(when unused data lines are tied to ground) is that i can see only one line(background dots) with no text!...when unused data lines are not connected the 2 lines with no text....i've tried all possible means but with no success!
A 12Vdc connected to 7805 is normal practice, what decoupling do you have on the 7805.?
Are there any other devices drawing current from the 7805.?
Do you see any black pixel blocks on the LCD.?
i have 100uF electrolyte at the input and 10uF electrolyte at the output.
at the moment only the AVR microcontroler(ofcourse and a potentiomenter connected to the internal ADC of the AVR) and LCD are drawing current from 78L05
Yes, there are black pixel blocks on the LCD but no text.
hi
Are the pixel blocks totally black.?
You should have a 10K variable resistor between +5v and 0V with the slider of the pot going to the LCD contrast pin, the pot should be adjusted just to show faint pixel blocks.
If the OP's LCD_command() function is writing full 8 bits as two nybbles, could that be a problem during 4-bit initialization sequence?
I use a special command just for sending a single 4-bit nybble during the 4-bit initialization procedure;
Mike
void InitLCD()              //
  delay_ms(15000);          // 4-bit initialization procedure
  PutLCD(nyb,3);            // wr 1 nybble (8 bit mode, includes 160 us delay)
  delay_us(4100);           //
  PutLCD(nyb,2);            // wr 1 nybble, switch to 4 bit mode
                            // now write 2 nybbles every time
  PutLCD(cmd,0x28);         // 4 bit mode, 2 lines, 5x7 font
  PutLCD(cmd,0x08);         // display off, cursor off, blink off
  PutLCD(cmd,0x01);         // clear display (includes 1.55 msec delay)
  PutLCD(cmd,0x06);         // cursor inc, shift off
  PutLCD(cmd,0x0C);         // display on, leave cursor off
Mike
void InitLCD()              //
  delay_us(4100);           //
maybe this could work! how do u define your PutLCD() function
If writing 8 bits is the problem then a write nibble function should solve it,
[COLOR="Blue"]void LCD_nibble(unsigned char nibble){
    LCD_DATA_PORT = (nibble & 0xF0)|(LCD_DATA_PORT & 0x0F);
    LCD_enable();
}[/COLOR]
void LCD_init()
[COLOR="blue"]    _delay_ms(15);		//start of required sequnce
    LCD_nibble(0x30);
    _delay_ms(5);
    LCD_nibble(0x30);
    _delay_ms(1);
    LCD_nibble(0x30);
    _delay_ms(1);
    LCD_nibble(0x20);		//switch to 4 bit mode[/COLOR]
   LCD_start();
   LCD_function_set();
    _delay_us(40);
   LCD_display_off();
   _delay_us(40);
   _delay_ms(2);
   LCD_mode_set();
   LCD_display_on();
The blue bits are the changes from your original code.
This is my first attempt from a month ago. It's pretty messy and I'm still adding types to the function but here's how I did it (below).
I didn't include the lcd_nyb() function because it's hard-coded for the 2-pin Myke Predko 74LS174 LCD interface rather than the standard 6 or 7 pin 4-bit interface that you're using but it should give you an idea of how I send the single nybbles that I believe are required during the 4-bit LCD initialization procedure.
Mike
#define cmd 0                   // LCD RS = 0
#define dat 1                   // LCD RS = 1
#define nyb 2                   // LCD RS = 0
void PutLCD(unsigned char ptype, unsigned char pbyte)
  unsigned char temp;
  if(ptype.1)                   // if 'dat' type
    RS = 1;                     //
  else                          // a 'nyb' or 'cmd' type
    RS = 0;                     //
  temp = pbyte / 16;            //
  if(ptype != nyb)              // if not 'nyb' type
    lcd_nyb(temp);              // send the hi nybble
  temp = pbyte & 15;            //
  lcd_nyb(temp);                // send the lo nybble
  delay_us(150);                //
  if(ptype == cmd)              // if 'cmd' type and
    if(pbyte < 3)               // if 'clear' or 'home' command
      delay_us(1400);           // delay additional 1.4 msecs
void PutLCD(rom char *pdata)    // "overload", PutLCD("K8LH Clock")
  char n = 0;                   //
  char temp;                    //
  while(temp = pdata[n++])      //
    PutLCD(dat,temp);           //
t.man,
Please try Pommie's procedure. It looks like the perfect solution.
Also look into your contrast hardware. A chap over on Forum.Microchip uses fixed resistors but I seem to recall he uses two resistors as a voltage divider. Your single resistor to ground may be a problem.
Mike
they r not totally black.
Actually i've connected 120 ohm resistor from contrast pin to ground, could that be a problem?
I would recommend you follow Pommie and Mike's guidance on the program.
When you said black, my concern was that the pixel blocks were totally black, in that case you would not see any characters that were being displayed..:)
When you get it working, fit a small 10K pot to give optimum contrast.
