MrMikey83 said:OK, it figures that I would have problems after etching a PCB and trying to use this pin.
Well, when I tested it, I used it as an output and it worked fine. Without thinking about it, I made the PCB so that it would be an input. Well, when I try to read from it, my LCD display doesn't show anything.
MrMikey83 said:In fact, several of the LCD pins can be used as IO pins in between LCD write sequences. You just have to save the PORT and DDR value, use the port, then set them back after your done.
