I have the powertip PC1602K 16*2 LCD display--datasheet link below.
https://www.electro-tech-online.com/custompdfs/2010/01/pc1602ky4.pdf
Using Nigel's (may I call you by your first name?) tutorials with a 16F628A I am able to make LEDs flash and run, alter sequences, etc. I progam with Pickit2.
I am unable to make the LCD display work.
I c/p the code to MPLAB, build it successfully, watch the outputs in SIM. All seems to go as designed. The LCD backlight works fine. I've tried adjusting the contrast.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
How do I test the LCD?? Will LEDs on the porta outputs be helpful? Ideas?
Thanks in advance!!!!
