LCD letter 'a' problem
hhhsssmmm
Hello
Im using a PIC18F4220 @ 20Mhz ceramic with C18 compiler.
Im trying to do a simple test program where the PIC sends out the letter 'a' to an LCD connected to PORTD (8bit mode).....no nibbling!
However I can not get a consistent result each time the PIC is powered up. The behaviour is that sometimes the letter 'a' is displayed perfectly and sometimes it is not displayed at all. Sometimes the cursor simply blinks or sometimes the display remains completely blank.
Im using the following LCD module from Palm Technology Co., LTD
Display: LCD 20x2
Model: PMC2002D9-SBLW-1
Below is my test program. Please can some one help me to get the stable letter 'a' result each time the PIC is powered up.
Thank you
Haseeb
#include <p18f4220.h>
#include <delays.h>
#pragma config OSC = HS
#pragma config WDT = OFF
#pragma config LVP = OFF
void SendLCD(unsigned char Byte, unsigned char type);
#define LCD LATD //LCD Latch PORT
#define LCD_RS LATEbits.LATE0 //Register Select (0: Instruction/ 1: Data)
#define LCD_E LATEbits.LATE2 //Enable (Starts data read/write)
void main (void)
    ADCON1 = 0x0F; //SET ALL PORTS as DIGITAL I/O
    PORTD = 0; //initiallize PORTD
    TRISD = 0x00; //LCD output
    PORTE = 0; //initiallize PORTE
    TRISEbits.TRISE0 = 0;  //LCD Register Select (to LCD Pin 4)
    TRISEbits.TRISE2 = 0;  //LCD Enable (to LCD Pin 6)
    //Initialize the LCD
    LCD = 0x00; //clear LCD PORTD pins
    Delay1KTCYx(100); //delay 20mS
    SendLCD(0x03,0); //Initialization command
    Delay1KTCYx(25); //delay 5mS
    Delay10TCYx(75); //delay 150uS
    SendLCD(0x3C,0); //Interface lenght is 8 bits long, 2-lines, 5x10 dots
    Delay10TCYx(25); //delay 50uS
    SendLCD(0x10,0); //Turn off LCD
    SendLCD(0x01,0); //Clear LCD
    SendLCD(0x06,0); //Increment the cursor after each byte written
    SendLCD(0x0F,0); //Turn on LCD, cursor on, cursor blinking on
    SendLCD(0x80,0); //Send 0x80 to set line to 1
    SendLCD('a',1); //print letter 'a' on LCD
    while(1); //loop forever
} //end of main()
    LCD_RS = type; //Set whether it is a Command (0) or Data/Char (1)
    LCD = 0x00; //Clear the LCD PORTD
    LCD = Byte; //assign the new data to the LCD PORTD
    //Toggle the E(enable)
    LCD_E = 1; //Set Enable High
    //Delay 5uS
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    Nop();
    LCD_E = 0; //Set Enable Low
i dont know if this is normal, but sometimes while using atmegas, the chip has to be reset a few times so that the LCD works, my guess is that its just a comunication problem caused by bad connections.
In my opinion i think there can be issue either with the delay routines or the connection in circuit. Its mostly connection issue for LCDs.
One more thing,
If i were you, i would make two separate functions
SendCommand(Command);
SendData(Data);
and all the necessary delays would be in those functions.
So the code would be like:
SendCommand(0x03);
SendCommand(0x3C);
Also having more delay in initialization is not a problem. I think your LCD is not initialing properly.
Wrong delays seem to make for the majority of the "it does not work" / "it does not work properly" problems with LCDs
Try this:
SendLCD((unsigned char)'a',1); //print letter 'a' on LCD
or
unsigned char temp = 'a';
SendLCD(temp,1); //print letter 'a' on LCD
