With reference to what?
For what use?
Picture Quality,Longivity,Cost and Power Consumption for TV or PC Monitor on these technologies !
LED lit ones have the advantage of been slightly more power friendly, and are thinner - that's really about it.
CCFL's are proven, reliable and long lasting, LED's are too new to know - but it's unlikely they will last longer than CCFL's (which are rarely the cause of failure anyway).
not true. LEDs are a tried and true tech that will last longer and is more efficient. about the only fact there is that it is not usually the CCFL that fails: it is normally the inverter.
LED's aren't a 'tried and tested' technology for LCD backlighting - and looking at the failure rate of LED's in car lights it's not a greatly relaible technology.
Inverter failure is more common than lamp failure, but it's by no means the most common failure mode of LCD panels.
LOL the LEDs are not what is failing unless they are over driven! That would be bad design or assembly and not the LEDs themselves!
Firstly the question itself is misleading. LCD is a screen and LED is a bulb.
An LED as a part itself when driven correctly with proper heat dissipation will last extremely long. Longer than CCFL tube for sure.
LEDs are somewhat tried & tested in backlighting. Try recalling old phones and gadgets with yellow/green backlit? I believe one of the reason it is being used now and not earlier for white backlighting is the efficiency and brightness improved over the years.
Of course it's the LED's that fail - I've changed loads of themand not in low cost cars either.
there are over driven LEDs and crap LEDs. properly driven quality LEDs DO NOT BLOW! they fade slowly into oblivion
They haven't been used in TV before - and it's an entirely different technology - as CCFL's usually outlast the rest of the panel, any imaginary longer life of LED's is pretty pointless anyway.
Ah now TV is brought into the discussion.
LCD backlighting in phones, copiers and TV works the same way. As i said it is used in TV only recently because of the high brightness available now.
CCFL does fails although not common, but it will become even more rare when LED is used. The chance of backlight failing is much lower.
You mean LED's driven well below their maximum limits - which LED's in TV screens are unlikely to be, just like car LED's aren't.
no i mean any condition that runs them at over 100C junction temp. I don't give a crap whether it is because they are driven at absolute max with less than an infinite heat sink or if they are driven at half standard with no heat sink. and not cheap Chinese knock off LEDs either, the fact of the matter is that you have no clue what the source of the LEDs are that you are replacing.
we replace LEDs on backlights here too... then we told the supplier to use decent LEDs or lose the business... we have not had a problem since.
