LCD wiring up help
Spadez
Im looking to buy this LCD:
https://www.electro-tech-online.com/custompdfs/2010/05/DE-LM005.pdf
It says it has 16pins. However, I have two questions. Firstly, can someone explain in more details what these do:
- Register select
- Read / Write
- Enable signal
- Data bus
Secondly, are all the DataBus's necessary (I have seen people dont normally wire up all the pins, yet it still seems to work perfectly)?
Thank you for any help you can give.
https://www.electro-tech-online.com/custompdfs/2010/05/DE-LM005-1.pdf
- Register select Selects Write Characters or Commands
- Read / Write Select Read or Write to LCD controller
- Enable signal Strobes in the current Char or Command
- Data bus Character or Command data
It can be wired for either 4 or 8 data/command lines, uses top 4 bits for 4 wire.
OK.?
EDIT:
Look at this pdf
  • how2lcd1.pdf
