Dragon Tamer
I have written the folowing code simply to test that everything in my code is working properly before moving on. The problem that I am having is when the LCD is supposed to initilise. No matter how many times I run the code that I have writen, the program will not initilise the LCD, but as soon as I run the program that the BASIC compiler generates, it works perfectly, even after I add my code and run it. This has left me assuming that my problem lies in my LCD initilise section of code.
That is the code that I wrote (the LCD is initlised at the LCD_START secton), this is the code that the BASIC compiler generates from one of it's example codes:
The only thing that I can see is done differently is that the BASIC generated code has 3, 4 bit resets where as mine only has 2. (I intend on changing some of the initilisation commands for my code)
;PIC18F242
;Port A is connected to the LCD
;Port B is connected to the keypad
;Port C is connected to the lights
;Cristal frequncy for this version is 4MHz
key equ 0x000
rows equ 0x001
CHAR equ 0x002
INS equ 0x003
mult equ 0x004
d1 equ 0x005
d2 equ 0x006
d3 equ 0x007
d4 equ 0x008
d5 equ 0x009
org 0018h
retfie
org 0008h
retfie
org 0000h
movlw 0x05
movwf mult
start_l call delay_100us
decfsz mult, f
goto start_l
movlw b'000000'
movwf TRISA
clrf PORTA
movlw b'11110000'
movwf TRISB
clrf PORTB
movlw b'00000000'
movwf TRISC
clrf PORTC
;63h and BDh need to be loaded
;into the T0 high and T0 low register, respectively
LCD_START
bcf PORTA,4
bcf PORTA,5
movlw 0x0A
movwf mult
sloop call delay_100us
decfsz mult,f
goto sloop
movlw 0x33
call SEND_INS
movlw 0x33
call SEND_INS
movlw 0x32
call SEND_INS
movlw 0x2C
call SEND_INS
movlw 0x06
call SEND_INS
movlw 0x0C
call SEND_INS
movlw 0x01
call SEND_INS
movlw 0x02
call SEND_INS
LCD_WELCOME
movlw 0x48 ;H
call SEND_CHAR
movlw 0x65 ;e
call SEND_CHAR
movlw 0x6C ;l
call SEND_CHAR
movlw 0x6C ;l
call SEND_CHAR
movlw 0x6F ;o
call SEND_CHAR
movlw 0x20 ;space
call SEND_CHAR
movlw 0x57 ;W
call SEND_CHAR
movlw 0x6F ;o
call SEND_CHAR
movlw 0x72 ;r
call SEND_CHAR
movlw 0x6C ;l
call SEND_CHAR
movlw 0x64 ;d
call SEND_CHAR
movlw 0x21 ;!
call SEND_CHAR
Next_word
movlw 0x10
movlw mult
nloop call delay_1ms
decfsz mult,f
goto nloop
movlw 0x01
call SEND_INS
movlw 0x02
call SEND_INS
movlw 0x57 ;W
call SEND_CHAR
movlw 0x68 ;h
call SEND_CHAR
movlw 0x61 ;a
call SEND_CHAR
movlw 0x74 ;t
call SEND_CHAR
movlw 0x20 ;space
call SEND_CHAR
movlw 0x6B ;k
call SEND_CHAR
movlw 0x65 ;e
call SEND_CHAR
movlw 0x79 ;y
call SEND_CHAR
movlw 0x3F
call SEND_CHAR ;?
movlw 0xC0
call SEND_INS ;go to line 2 home
Notify
movlw 0xff
movwf PORTC
Chk_Keys
movlw 0x00 ;wait until no key pressed
movwf PORTB ;set all output pins low
movf PORTB, W
andlw 0x0F ;mask off high byte
sublw 0x0F
btfsc STATUS, Z ;test if any key pressed
goto Keys ;if none, read keys
call delay_1ms
goto Chk_Keys ;else try again
Keys
call Scan_Keys
movlw 0x10 ;check for no key pressed
subwf key, w
btfss STATUS, Z
goto Key_Found
call delay_1ms
goto Keys
Key_Found
clrf PORTC
movf key, w
andlw 0x0f
call J_TBL ;lookup key in table
movwf key ;save back in key
return ;key pressed now in W
Scan_Keys
clrf key
movlw 0xF0 ;set all output lines high
movwf PORTB
movlw 0x04
movwf rows ;set number of rows
bcf STATUS, C ;put a 0 into carry
Scan
rrncf PORTB, f
bsf STATUS, C ;follow the zero with ones
;comment out next two lines for 4x3 numeric keypad.
btfss PORTB, 7
goto Press
incf key, f
btfss PORTB, 6
goto Press
incf key, f
btfss PORTB, 5
goto Press
incf key, f
btfss PORTB, 4
goto Press
incf key, f
decfsz rows, f
goto Scan
Press
return
J_TBL
dcfsnz key, f
goto _0
dcfsnz key, f
goto _1
dcfsnz key, f
goto _2
dcfsnz key, f
goto _3
dcfsnz key, f
goto _4
dcfsnz key, f
goto _5
dcfsnz key, f
goto _6
dcfsnz key, f
goto _7
dcfsnz key, f
goto _8
dcfsnz key, f
goto _9
dcfsnz key, f
goto _A
dcfsnz key, f
goto _B
dcfsnz key, f
goto _C
dcfsnz key, f goto _D
dcfsnz key, f
goto _E
dcfsnz key, f
goto _F
return
_0
movlw 0x30
call SEND_CHAR
goto CHK_KEYS
_1
movlw 0x31
call SEND_CHAR
goto CHK_KEYS
_2
movlw 0x32
call SEND_CHAR
goto CHK_KEYS
_3
movlw 0x33
call SEND_CHAR
goto CHK_KEYS
_4
movlw 0x34
call SEND_CHAR
goto CHK_KEYS
_5
movlw 0x35
call SEND_CHAR
goto CHK_KEYS
_6
movlw 0x36
call SEND_CHAR
goto CHK_KEYS
_7
movlw 0x37
call SEND_CHAR
goto CHK_KEYS
_8
movlw 0x38
call SEND_CHAR
goto CHK_KEYS
_9
movlw 0x39
call SEND_CHAR
goto CHK_KEYS
_A
movlw 0x41
call SEND_CHAR
goto CHK_KEYS
_B
movlw 0x42
call SEND_CHAR
goto CHK_KEYS
_C
movlw 0x43
call SEND_CHAR
goto CHK_KEYS
_D
movlw 0x44
call SEND_CHAR
goto CHK_KEYS
_E
movlw 0x45
call SEND_CHAR
goto CHK_KEYS
_F
movlw 0x46
call SEND_CHAR
goto CHK_KEYS
LCD_CLR
movlw 0x01
call SEND_INS
return
LCD_1HOME
movlw 0x02
call SEND_INS
return
LCD_2HOME
movlw 0xC0
call SEND_INS
return
LCD_ON
movlw 0x0C
call SEND_INS
return
LCD_OFF
movlw 0x08
call SEND_INS
return
LCD_CBLINK
movlw 0x0D
call SEND_INS
return
LCD_CUL
movlw 0x0E
call SEND_INS
return
LCD_CBLINKUL
movlw 0x0F
call SEND_INS
return
LCD_LEFT
movlw 0x10
call SEND_INS
return
LCD_RIGHT
movlw 0x14
call SEND_INS
return
LCD_SLEFT
movlw 0x18
call SEND_INS
return
LCD_SRIGHT
movlw 0x1C
call SEND_INS
return
LCD_1CLR
movlw 0x80
call SEND_INS
return
LCD_2CLR
movlw 0xC0
call SEND_INS
return
LCD_1POS
iorlw 0x80
call SEND_INS
return
LCD_2POS
iorlw 0xC0
call SEND_INS
return
SEND_CHAR ;send a charicter to the LCD
MOVWF R4L
BSF LATA,4
SWAPF R4L,F
MOVLW 0xF0
ANDWF LATA,F
MOVF R4L,W
ANDLW 0x0F
IORWF LATA,F
BSF LATA,5
NOP
BCF LATA,5
NOP
SWAPF R4L,F
MOVLW 0xF0
ANDWF LATA,F
MOVF R4L,W
ANDLW 0x0F
IORWF LATA,F
BSF LATA,5
NOP
BCF LATA,5
NOP
MOVLW 0x64
MOVWF R4L
call delay_100us
RETURN
SEND_INS ;send an instruction to the LCD
MOVWF R4L
BCF LATA,4
SWAPF R4L,F
MOVLW 0xF0
ANDWF LATA,F
MOVF R4L,W
ANDLW 0x0F
IORWF LATA,F
BSF LATA,5
NOP
BCF LATA,5
NOP
SWAPF R4L,F
MOVLW 0xF0
ANDWF LATA,F
MOVF R4L,W
ANDLW 0x0F
IORWF LATA,F
BSF LATA,5
NOP
BCF LATA,5
NOP
MOVLW 0x88
MOVWF R4L
MOVLW 0x13
MOVWF R4H
call delay_100us
RETURN
delay_1us ;4MHz 1us delay (wait 4 cycles)
nop ;1 cycle each
nop
return ;1 cycle
delay_10us ;40 cycles
movlw 0x0C
movwf d1
_10us
decfsz d1, f
goto _10us
return
delay_100us ;400 cycles
movlw 0x84
movwf d1
_100us
decfsz d1, f
goto _100us
return
delay_1ms
movlw 0x04
movwf d2
l_loop
movlw 0x6F
movwf d1
_1ms
decfsz d1,f
goto _1ms
decfsz d2,f
goto l_loop
return
delay_10ms
delay_100ms
movlw 0x1F ;31
movwf d1 ;
movlw 0x4F ;79
movwf d2 ;4 cycles
_100ms
decfsz d1, f ;1 cycle (skiping=2)
goto _100ms1 ;2 cycles
decfsz d2, f ;1 cycle
_100ms1 goto _100ms ;2 cycles
return ;2 cycles
delay_1s
movlw 0x08 ;8
movwf d1
movlw 0x2F ;47
movwf d2
movlw 0x03 ;3
movwf d3 ;6 cycles
_1s
decfsz d1, f ;1 cycle (2 when skiping)
goto _1s2 ;2 cycles
_1s2 goto _1s3 ;2 cycles
decfsz d3, f ;1 cycle
_1s3 goto _1s ;2 cycles
nop
return ;3 cycles
Define LCD_BITS = 4
Define LCD_DREG = PORTA
Define LCD_DBIT = 0
Define LCD_RSREG = PORTA
Define LCD_RSBIT = 4
Define LCD_EREG = PORTA
Define LCD_EBIT = 5
Lcdinit 0
Lcdout "Hello World!"
