LDR programming with C
hashoom89
hi
please i need help to programming microcontroller PIC18f4550
the program must sense LDR sensor
and in this project i used dc motor to control blinds open or closed
please i need your help
Here a little sample for your chip to use ADC It should work
unsigned int temp_res;
void main() {
  ADCON1 = 0b00001110;              // Configure AN0 pin as analog
  ADCON0 = 0d00000001;                 // Configure other AN pins as digital I/O
  TRISA  = 0xFF;              // PORTA is input
  TRISC  = 0;                 // PORTC is output
  TRISD  = 0;                 // PORTD is output
  do {
    temp_res = ADC_Read(0);   // Get 10-bit results of AD conversion
    PORTD = temp_res;         // Send lower 8 bits to PORTD
    PORTC = temp_res >> 8;    // Send 2 most significant bits to RC1, RC0
  } while(1);
// this code should light up 10 leds 8 of them on portd and the last 2 portc 0,1
