Hi All,
My mind gone blank for the moment on how best to solve a friends problem, hoping you could help.
He has a small boat and has fitted an aftermarket 12V LED 'light' to the top of his mast. It periodically blows.
On having a look around his boat I'm pretty sure he's running the module straight from the normal 12V battery - I'm thinking the alternator charging the battery (13.2-14V) is possible over stretching the unit or evan a PIV issue is occuring
OK presuming I'm right on either or both, obviously a reverse biased diode woill solve the PIV issue but what about a simple voltage regulator to supply the LEDS.
A 78x12 is the a simple solution but I'm unsure on the headroom voltage needed to get a nice 12V output.
Another thought is a Zener (could you help on the design values e.g. power disipation, current limiting resistors etc)
Lastly, I thought an inductor in series to smooth out any ripples the advantage being the power handling abilities(again design formulae would be great)
Any other suggestions would be greatly appreciated
Thanks in advnce
Dotnet
Thanks in advnce
Dotnet
