The circuit I am trying to create is powered by a 3.6v rechargeable battery. On depression of a switch, I need a motor to run, and 4 red LEDs to light. After ~3 seconds, I need the red LEDs to turn off and be replaced by 4 green LEDs which will gradually fade over a period of ~3 seconds. On release of the switch, I need the motor to turn off, but still allowing the green LEDs to fade to zero brightness.
I understand that i need to incorporate a capacitor across the power supply (after the switch) so turning the switch off leaves the green LEDs running from the capacitor charge; however, at present, the only way i can achieve close to what i need is by using 2 separate circuits (one for the motor and red LEDs and the other to charge the capacitor and green LEDs), and having to change between LEDs manually with 2 different switches.
I haven't a clue how to keep the red LEDs on for a specific time span and then instantaneously turn them off and replace them with the fading green LEDs...
Any help would be very much appreciated!
Thanks, Matt.
Thanks, Matt.
