LED panel psu question
Anonymous1
Hello,
I'm new to the forum, what a great find! I see there are some really keen evil geniuses around here, so I hope I can glean some insight from you all.
I want to populate an area appr 1.5" - 2" diameter on a board with 5mm LEDs and drive this with batteries, and be able to recharge the batteries with an off the shelf DC supply, like a 5v, 6v or 12v you use for home electronics. It would be nice to also run this off the DC supply and only on the batteries when needed.
The number of LEDs in the array are not a given, and could be in parallel or parallel\series. I have a 32 LED flashlight, and it is about the size I am suggesting, so the qty may be around 32-40ish. They are not all the same LEDS, the values vary slightly.
Here's the specs:
Forward Voltage VF max 4.0 typ 3.6 V
Continuous Forward Current 20 mA
Forward Voltage VF max 4.0 typ 3.7 V
Continuous Forward Current 30 mA
Forward Voltage VF max 4.0 typ 3.5 V
I would appreciate your ideas on
1) the ability to drive these from a regulated external source as mentioned
2) the ability to run this off of rechargeable batteries
3) the ability to drive a mix of LEDs with the least amount of resistors, for instance, do I really need 1 resistor per LED or can I bind 10 of them through one resistor?
4) if I use batteries in parallel to handle the load, what consideration would I need to use in making this rechargeable without zapping the LEDs? Can I recharge them if they are in series at all?
I know this is a bit much, but maybe I can some insight on one part at a time and piece this together.
THANK YOU for your time and efforts!!
Cheers
You could go with a parallel circuit using one resistor per bank (or banc if in Europe).:D
You could put 2 in series with one resistor, if using a 12V battery or power supply. This will have the benefit of using less current, assuming each LED is drawing 20/30mA from the supply.
Subtract the Vf drops for the LEDs from the Vs and use ohm's law (R = V/I) to calculate the value of the resistor you need for optimum brightness. If series parallel, make sure all the LEDs are the same type.
What battery to go with will depend on the app you are using it in (i.e. How long will it be required to run continuous?). Consider dropping your LED current a little if you want to recharge in-circuit. The recharge voltage will be higher than the operating voltage of the battery (~= 13.5-14.4). This will increase your current through the LEDs and over-stress them if they are drawing 20mA @ 12V. Make your calculations base on the recharge voltage.
If you explain what this will be used for exactly, maybe I could give you better advice.
