Led Segment Display Driver Help (duplex drive)
GooseElectro
I have a seven segment display that i would like to use in a project however i can find a driver chip for it.
The display is a LD4052 - 11. A seven segment, dual digit display. it is common anode and the data sheet says it is duplex drive , (it only has 10 pins to control both digits)
The data sheet is attached.
thank you for any suggestions.
  • ld4052.pdf
