Dirk.S
Hello Gentlemen
I'm currently working on a Li-Ion charger circuit and have had a look at two different ICs to do the job. Both from Texas Instruments.
The first is BQ24160YFFT capable of delivering 2.5A and the second is BQ24123RHLT capable of delivering 2A.
I am planning to use a 3.7V 6600mAh battery pack. From what I understand you shouldn't charge a battery with a current rating more then 1C. The battery pack consists off 2200mAh cells. So that means that I shouldn't charge with a current of more then 2200mAh but if there are three cells in parallel that means that if I apply a current of say 3A through a Li-Ion charging ic to a 3 cell battery pack the current should roughly split evenly between the three cells meaning that roughly 1A should flow to each cell? Now am I reasoning correct here or not if there is only a positive and negative wire coming out of the battery pack?
My objective is to be able to charge the battery pack with a charge current of 2.1A so that I will be able to charge the battery pack in about +-3.5 hours. Your input is greatly appreciated.
