things
hi all, i have a very small lightweight battery out of a remote control plane. it is covered in foil stuff, and has a little circuit attached. i presume it is a li-poly battery, as that is what it said on the packaging. i am trying to run an led of it, and it does work, but then the output stops. if i hook the led directly to the battery(before the circuit) it works fine. my question is, what does this circuit do? can i remove it? and why does the output stop after about 10 seconds? i will try to get a pic now.
thanks
thanks
