Hi Friends,
With the help of this forum and going through various tutorials in the internet I have managed to make a moving message display using MCU 16F72 and shift register 74HC595. The project works. But since the MCU has only 2K of Program Memory, thought to use 16F886 to have a longer message displayed. When I compiled the code and tried to build, an error message was shown like this -
"Error - section 'MAIN_PROG' can not fit the section. Section 'MAIN_PROG' length=0x00001020
Errors : 1
Link step failed."
However, if the data of message to be displayed is reduced, say 2024 byte, the code builds successfully.
I cannot make out what does this error mean. Practically it is seen that both the MCUs can handle same amount of message data though 16F886 has a program memory capacity of 8K and data memory of 368 byte whereas 16F72 has only 2k of program memory and 128 byte of data memory.
The code is given. Please forgive for not giving the comment.
Would you kindly help me in this matter?
swapan
Errors : 1
Link step failed."
swapan
; Files required: P16F886.INC *
; Notes: *
list p=16f886 ; list directive to define processor
#include <p16f886.inc> ; processor specific variable definitions
; '__CONFIG' directive is used to embed configuration data within .asm file.
; The labels following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
__CONFIG _CONFIG1, _LVP_OFF & _FCMEN_ON & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT
__CONFIG _CONFIG2, _WRT_OFF & _BOR21V
;***** VARIABLE DEFINITIONS (examples)
cblock 0x20
col_count ; variable used for context saving
view_count
mask
ptrl
ptrh
count1
count2
row_count
bit_count
temp_ptrl
temp_ptrh
endc
#define Serial_Data PORTB,4;
#define SH_Clk PORTB,6;
#define ST_Clk PORTB,7;
#define row_data PORTC,3;
#define clear PORTC,2;
#define clk PORTC,1;
; example of using Shared Uninitialized Data Section
INT_VAR UDATA_SHR
w_temp RES 1 ; variable used for context saving
status_temp RES 1 ; variable used for context saving
pclath_temp RES 1 ; variable used for context saving
; example of using Uninitialized Data Section
TEMP_VAR UDATA ; explicit address specified is not required
temp_count RES 1 ; temporary variable (example)
RESET_VECTOR CODE 0x0000 ; processor reset vector
nop
goto start ; go to beginning of program
INT_VECTOR CODE 0x0004 ; interrupt vector location
INTERRUPT
movwf w_temp ; save off current W register contents
movf STATUS,w ; move status register into W register
movwf status_temp ; save off contents of STATUS register
movf PCLATH,w ; move pclath register into w register
movwf pclath_temp ; save off contents of PCLATH register
; isr code can go here or be located as a call subroutine elsewhere
movf pclath_temp,w ; retrieve copy of PCLATH register
movwf PCLATH ; restore pre-isr PCLATH register contents
movf status_temp,w ; retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,f
swapf w_temp,w ; restore pre-isr W register contents
retfie ; return from interrupt
MAIN_PROG CODE
start
bsf STATUS,RP0
movlw 00h
movwf TRISA
movlw 00h
movwf TRISB
movlw 00h
movwf TRISC
movlw 06h
movwf ADCON1
movlw b'10000111'
movwf OPTION_REG
;bsf STATUS,RP1
;bsf STATUS,IRP
;movlw b'00000000'
;movwf ANSEL
;movlw b'00000000'
;movwf ANSELH
bcf STATUS,RP0
;bcf STATUS,RP1
;bcf STATUS,IRP
movlw high(table) ; table address hi
movwf ptrh ;
movlw low(table) ; table address lo
movwf ptrl ; ptrh:l = &table[0]
initial_run:
movlw d'5'
movwf view_count
Run_1:
movf ptrh,W ;
movwf temp_ptrh
movf ptrl,w
movwf temp_ptrl
movlw d'1'
movwf mask
movlw d'96'
movwf col_count
movlw d'8'
movwf row_count
movlw d'8'
movwf bit_count
bcf clear
nop
bsf clear
bsf row_data
Run_2:
call read_table
goto data_feed
data_feed:
andwf mask,w
btfsc status,z
goto low_data
goto high_data
low_data:
bcf serial_data
bsf SH_Clk
nop
bcf SH_Clk
decfsz col_count,1
goto next_col
bsf clk
nop
bcf clk
bcf row_data
bsf ST_Clk
nop
bcf ST_Clk
call view_delay
decfsz bit_count,1
goto next_row
goto second_set
high_data:
bsf serial_data
bsf SH_Clk
nop
bcf SH_Clk
decfsz col_count,1
goto next_col
bsf clk
nop
bcf clk
bcf row_data
bsf ST_Clk
nop
bcf ST_Clk
call view_delay
decfsz bit_count,1
goto next_row
goto second_set
next_col:
incf temp_ptrl,f
skpnz
incf temp_ptrh,f
incf temp_ptrl,f
skpnz
incf temp_ptrh,f
goto Run_2
next_row:
decfsz row_count,1
goto row_scan
goto second_set
row_scan:
rlf mask,1
movf ptrh,W ;
movwf temp_ptrh
movf ptrl,w
movwf temp_ptrl
movlw d'96'
movwf col_count
goto Run_2
second_set:
movf ptrh,W ;
movwf temp_ptrh
movf ptrl,w
movwf temp_ptrl
movlw d'1';
movwf mask
movlw d'96'
movwf col_count
movlw d'8'
movwf row_count
movlw d'8'
movwf bit_count
incf temp_ptrl,f
skpnz
incf temp_ptrh,f
goto Run_3
Run_3:
call read_table
goto data_feed_1
data_feed_1:
andwf mask,w
btfsc status,z
goto low_data_1
goto high_data_1
low_data_1:
bcf serial_data
bsf SH_Clk
nop
bcf SH_Clk
decfsz col_count,1
goto next_col_1
bsf clk
nop
bcf clk
bcf row_data
bsf ST_Clk
nop
bcf ST_Clk
call view_delay
decfsz bit_count,1
goto next_row_1
decfsz view_count,1
goto Run_1
incf ptrl,f
skpnz
incf ptrh,f
incf ptrl,f
skpnz
incf ptrh,f
movlw d'5'
movwf view_count
goto Run_1
high_data_1:
bsf serial_data
bsf SH_Clk
nop
bcf SH_Clk
decfsz col_count,1
goto next_col_1
bsf clk
nop
bcf clk
bcf row_data
bsf ST_Clk
nop
bcf ST_Clk
call view_delay
decfsz bit_count,1
goto next_row_1
decfsz view_count,1
goto Run_1
incf ptrl,f
skpnz
incf ptrh,f
incf ptrl,f
skpnz
incf ptrh,f
movlw d'5'
movwf view_count
goto Run_1
next_col_1:
incf temp_ptrl,f
skpnz
incf temp_ptrh,f
incf temp_ptrl,f
skpnz
incf temp_ptrh,f
goto Run_3
next_row_1:
decfsz row_count,1
goto row_scan_1
goto second_set
row_scan_1:
rlf mask,1
movf ptrh,W ;
movwf temp_ptrh
movf ptrl,w
movwf temp_ptrl
incf temp_ptrl,f
skpnz
incf temp_ptrh,f
movlw d'96'
movwf col_count
goto Run_3
view_delay:
movlw d'2'
movwf count1
movlw d'255'
movwf count2
decfsz count2,1
goto $-1
decfsz count1,1
goto $-5
return
read_table:
movf temp_ptrh,w
movwf PCLATH ;
movf temp_ptrl,W ;
movwf PCL
table
dt 00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,00h,
;N
dt 0FFh,0FFh,0FFh,0FFh,000h,038h,000h,070h,000h,0E0h,001h,0C0h,003h,080h,007h,000h,00Eh,000h,01Ch,000h,0FFh,0FFh,0FFh,0FFh,000h,000h,000h,000h,
;A
dt 0FFh,0E0h,0FFh,0F0h,006h,038h,006h,01Ch,006h,00Eh,006h,007h,006h,007h,006h,00Eh,006h,01Ch,006h,038h,0FFh,0F0h,0FFh,0E0h,000h,000h,000h,000h,
;N
;D
dt 0FFh,0FFh,0FFh,0FFh,0C0h,003h,0C0h,003h,0C0h,003h,0C0h,003h,0C0h,003h,0C0h,003h,0E0h,007h,070h,00Eh,03Fh,0FCh,01Fh,0F8h,000h,000h,000h,000h,
;I
dt 0FFh,0FFh,0FFh,0FFh,000h,000h,000h,000h,
;SPACE
END ; directive 'end of program'
