I have almost no electronics background. I heard you groan lol. What I am going to do in some fashion is create multiple sources of renewable energy wind and solar, into a central circuit that will feed a battery pack and then feed power into my abode.
One problematic stipulation is I cannot afford to buy much if any parts. I will be building all or almost all of this from scrap parts. Ceiling fans, fans, space heaters, etc. I will not be using solar panels for solar energy. Instead I'll build solar trees as I can build those from found materials. $100 is a pipe dream for me right now. I am moving into a tent and trying to drum up the $200-$400 they charge people with no income and no gov assistance to get cancer treatment. So if I had $200 it'd wind up spent on doctors bills not materials.
I will have some power in for times when there is no wind or sun or it's insufficient. Which will be most of the time until I add enough sources.
What I think I want to do, which is probably not the best way to do it is.
Energy sources feeding to a charge controller.
Charge controller to battery pack.
Battery pack to something to blend current from an extension cord with what's being generated. and that drawn off the battery pack. Which at the moment consists of a single battery.
Then extension cord(s) off that source to power space heaters, an AC in the summer, hot plate, microwave, etc.
So am I on the right track?
I don't see how I can get around buying a charge controller. I doubt I could make one from found materials. Especially one that wouldn't be a potential fire hazard. I expect to have a pretty significant power draw as it gets down to the single digits F here in the winter, and 110+ F in the summer. I am a musician and will need to record. I will also have a few computers running at all times, a mini-fridge, lights, space heater in the winter to supplement what heat I can get from a wood stove,
I have plenty of wire to work with. I scrap so I pick up lots of wire of all types and sizes. I also pick up all sorts of cieling fans, space hearers, etc with working motors. I've found some youtube vids and howtoos that appear to be good on converting these to generators, but nothing about what to do with that power afterwards. Obviously I cannot just run it direct to what I am powering or even a battery. I could overload the battery or destroy anything running AC power into something designed to use DC power. The power fluctuations alone would be a major problem.
I have plenty of space so I can set up hundreds of wind generators and solar trees as time allows.
I eat on about $150 a month. Getting a charge controller means not eating for most of a month assuming a $100 charge controller will do the trick. Buying multiple controllers would be prohibitively expensive. If I had to buy one for each power source there's no way I can afford that. From what research I've done, it will take a dozen or so of these things to produce enough electricity to power my stuff when there's a moderate or light wind.
So I need a way to channel the output of all of them into a single charge controller that sits in front of the battery(s).
Setting up the batteries seems pretty simple. I've found good information on how to do that.
It's going from the batteries and how to combine that with current coming in from an extension cord that has me baffled.
I'm sure some if not all of this is covered in FAQs somewhere and previous posts here. If somebody has the patience to put it in sequence I would greatly appreciate it. That is, you need to do this first with the power coming from the generators, then you need to do this before you hit the battery with it link to the FAQ/post, you need to do this after. I don't know the terminology well enough to find it myself or I'd not need to ask this question
Thanks.
Thanks.
