If eth0 is connected to some box (modem/router/switch) with an IP of 198.162.0.1 to configure it only.
wlan0 is on a 10.0.1.x network. Router on that network is 10.0.1.1
Linux box has an IP of 10.0.1.4 assigned with DHCP.
So, how can I put the 192.168.1.1 device on the 10.0.1.x network, but using the wired port on the laptop?
Even if the router was had an IP address on 10.0.1.x, how could I make it work?
Now, I can likely put the "some box" on the 10.0.0.1 network elsewhere.
Asides:
The modem makes no distinction between LAN and WAN ports.
It claims you can't access the modem when configged under bridge mode. The only way, is to reset it to factory defaults.
I'd love to be able to get line stats via telnet or reset it back to a stand-alone modem via telnet.
In the visible command help there is mention of a secondary IP address that may be able to be set.
There is telnet access to the box. Supposedly it's from both sides. I haven;t tried that yet. I could successfully telnet to the box when not connected to DSL which is the only way I tried. I was unable to use the GUI interface on another port.
Some commands are made visible by the interface and supposedly you can access the shell. I haven't tried.
It's a current product, but all ISP branded questions MUST be answered by the ISP. Maybe I need to buy an unbranded one to get questions answered?
The questions above don't address the purpose.
Asides:
