killer_fighting
Please refer the battery link from (https://www.overlander.co.uk/batteries-chargers/lipo-batteries/lipo-battery-4400mah-6s-22-2v-60c-extreme-pro.html)
I have bought two batteries (Lipo Battery 4400mAh 6S 22.2v 60C)as shown in subject for my project purpose. Below are my queries about those batteries:
1. When I direct the battery to motor, there is some huge sparks occurred. To prevent this happens again, I have installed a MAXI fuses in between the battery and motor. Does my
precaution allows me to get off from this problem? Does there is any precaution that I can do?
2. Regard with the fully charged battery, if I have 100 % fully charged battery for the battery, how many voltage that I will get back for the battery? It is 22.2 (V) or more than that? This is very important for my project! As I don't want burn out my electronic circuit.
This is rough drawing for my power system, please to the image below:
Lithium Polymer battery: (https://www.overlander.co.uk/batteries-chargers/lipo-batteries/lipo-battery-4400mah-6s-22-2v-60c-extreme-pro.html)
MAXI Fuses: (https://uk.farnell.com/littelfuse/0299020-zxocr/fuse-slow-blow-20a-maxi/dp/9943145)
SyRen 10A Motor Driver: (https://www.active-robots.com/contr...lers/syren-10a-regenerative-motor-driver.html)
Input voltage: 6-24V nominal, 30V absolute max.
Output Current: Up to 10A/20A continuous. Peak loads may be up to 15A/30A for a few seconds. These ratings are for input voltages up to 18v in still air without additional heatsinking. For thermal, airflow and voltage rating charts for voltages over 18V see the back inside cover.
