Lithium 5V stabilization
v4000ds
2-3 battery input
1) 2bt: min: 2*3.2=6.4V, mid 2*3.6=7.2V
2) If the chips for the first option are too expensive
3bt: min: 3*3.2=9.6V, mid 3*3.6=10.8V, max 3*4.2=12.6V
Out stable 4...5V, lower limit 4V. Current <=3A
The MC7805 is really only good for 1A maybe 1.5A. You need 3A. It needs 3 to 4 volts higher input than the output. That is a serious problem here.
There are "LDO" regulators where the input to output voltage can get down to less than 1 volt. Low Drop Out
Because you are running from batteries a "switching power supply" will make the batteries last much longer.
5A Here is a link to a DC-DC 5A buck power supply. It will work with the 3 battery option better. There are smaller 3A versions.
1.8A (3A short time) This one is maybe too small.
The good point about switching power supplies:
Using a MC7805, 3A load it will draw 3A from any battery voltage.
With a switcher 5V 3A out will pull only 1.5A from a 10V battery and only 1A from a 15V battery.
Much cheaper on ebay
True, cheaper, but direct from China you get 20 pieces for the price.
