Externet
Hello.
A plain tool lithium battery pack of -say 6 series- for 24V is not being charged. It sits idle for a few days now.
Is the 'balancing' circuitry in operation ? Are the battery pack 24V terminals feeding/powering the balancing circuitry in it ?
Was the balancing circuitry in operation last time while it was charging ?.
Will the circuitry be in operation when the tool is in use ?
When is the 'balancing' taking place ?
When is the management circuit not energized if it is always connected to all the cells ?
If a cell presents an anomaly; how is it corrected by the 'management circuitry ? Charges that cell more/less than the others ?
If a cell has a lower voltage -say 3V- and the rest are 4V each; put to charge, does the charger feeds the supply of the 'management circuit' inside the battery to 'get permission' to turn-on the charging or the pack itself does not produce/conduct/allow then the charging voltage ?
Read somewhere that not all packs have the 'balancing feature' and get just power at its main terminals, when temperature sensing and identification allows the charger to proceed applying the voltage recipe.
Am mostly talking about DeWalts... Yes, I have search engines too.
