redart
Looking for any help in diagnosing what might be wrong with the following circuit. It's the mains input stage for a turntable power supply, which I think is meant to feed the rest of the board (complex) with the indicated 13.5vdc coming from the collector of Q2. However when I measure this I get -120vdc, or 240vac depending on what meter range I use. The supply rail measures +120vdc. I can only get the indicated 115vac by lifting the -ve leads of C1 and C2, otherwise it's around 90vac. As there is mains voltage on the rest of the board I suspected the rectifier, however changing it hasn't helped. Any thoughts would be much aprreciated.
