crutschow submitted a new article:
LM317 Adjustable 20V, 1.5A Supply with Simple Tracking Preregulator - LM317 Power supply with switching tracking prereg for good efficiency and minimal heat sink reqmts.
Read more about this article...
The LM317 is a commonly used, rugged linear regulator with an adjustable output but suffers from the normal inefficiency of linear regulators which can require a large heatsink for the higher output currents, especially if input to output voltage drop is high.
To minimize this, a tracking, switching preregulator can be used to keep the voltage drop across the LM317 essentially constant, at a voltage slightly above the minimum required (3V) for proper regulator operation. This increases...
