LM339 doesn't go high
Siddu_N
Hi everyone,
Can someone please explain why the LM339 comparator's output doesn't go high, even when the positive input is more than the negative input.
No matter what i try, the output goes only to a few picofarads. when the negative input is higher than the positive input, then the comparator works fine and the output goes to - V saturation. Can someone shed some light on this?
Thanks in advance.
Hi everyone,
Thanks in advance.
Its an open output, it requires a pullup resistor to the V+ supply, about 3.9K.:)
Thanks for the reply.
I tried adding the resistor but it still doesn't go high. Where exactly do I add the resistor? Between the comparator and the positive input? or between the comparator and the positive supply? I tried both but still the output stays at a few picovolts..
Picovolts? So you are trying to simulate the circuit?
As Eric said it is an open collector output. So you add the resistor between the supply and the output.
Thanks a lot both of you.. Yeah i was simulating it before getting to build the actual circuit. Using it to build a programmable gain amplifier.
post yr schematic so that we might see .....
