Hi All.
After searching through the forums i can see this is a common problem - but i cant seem to work out what i need to buy to resolve my issue. I have a Velleman USB 8005 board which has an onboard ADC (8 bit) which takes 0-5v
Ive interfaced an LM35, but due to the low outputs i cant get the results i need ( im measuring temps circa 40-60 degrees celsuis ) - im only getting circa .4 to .8 volts for my temps so im unable to get any meaningful results from the ADC.
I see that i can use a 2 resitors across + and ground and take a reference of 2.5v which may increase the output scale by 2.
I also see that i can use an Op-Amp and scale the output from the LM35 by a factor of 5 which would give me the resolution required by both my application and the ADC.
My (rather long winded) question is - what op-amp and components would i need to buy to fabricate a 0-5v op-amp.
The LM35 and the ADC are all being fed from a 5v supply.
as you can tell, very new to all of this and still trying to get good electronics selection purchased to avoid the frequent trips to maplins.
thanks
David
thanks
David
