Hi All,
I have an idea about charging batteries using the main/solar.
Lets say that I have a current source of 300ma. I want to use an LM35DZ which if I read correctly has a range of 0 deg. C to 100 deg C. Each degree amounts to another 10mV added to the output. What I want is some way to limit the current based on the temperature of the batteries. Now I have learned that NPNs can be used to control the amount of Current based on the current applied to the base. However the current coming from the middle leg of the LM35DZ is pretty damn small.
Does anyone have an idea of what I can drive from the temperature voltage of the LM35DZ which can control the size of the 300mA current?
PS. I really want to keep things to simple readily available components - so monolithic IC etc are out of the question. If it can be kept down to simple components like transistors, capacitors, resistors etc that would be super.
Peter Dove
Peter Dove
