LM383T Volume idea?
Seven71ne
Hey everybody im new here, and this is my first post!
Well, im a senior in HS and im taking 2 electronics classes (analog and digital, both are really fun and ive learned so much)
Anyway, im really into amps, speakers, and the sort.
So i made a LM383T 8+ watt speaker (with a 6 ohm speaker i might add)
It works GREAT!!! But i was woundering... how can i use a POT to control the volume? Any Ideas?
I don't understand hows your amp works great without a volume pot control.
Do search on google 'audio amplifiers' where the schematics shows how to connect a pot to control volume.
See the 10K input pot used with LM386 to control the volume.
i also have it hooked to a 555 led blinker circuit, forgot to mention that (it also has a B100k ohm pot on the 555)
im also using a 383 not a 386... i just need to know what pins i need to connect the pot to..
It's pin 3 before C1 you have to connect the wiper of the pot. OK?
See the pic.
Hi Transistor,
Please don't copy schematics that have a backwards input capacitor and an important capacitor and an important resistor missing.:eek:
The pin numbers are wrong too.:rolleyes:
The volume control must be connected to the signal input, not to pin 1 nor to pin 3.:confused:
Pin 3 is ground and the ground terminal of the volume control connects there.
The LM383 has not been made for more than 10 years.:p
Hi Transistor,
Wrong pin nos. I agree, was in a hurry. Just searched on google ;)
The volume control must be connected to the pin 1 through 10uf cap :p:p
