I had a number of attempts with this chip with quite disappointing results.hi. i had successfully complete my speaker analogue circuit using LM386 with 8Ω speaker/0.25watt. but the sound is terrible at high volume. how do i make the sound clear at full volume?
Hmmm the ANY chip would have been a MIRACLE a century ago! I think you might have meant decade!I had a number of attempts with this chip with quite disappointing results.
LM386 is good for nothing, but experiments.Running it at full volume to a 250mW speaker is not at all a good idea. You need a 1W speaker at least.
It is a very old integrated circuit with high gain but low power. Result: Poor quality/distorted audio output especially when newbies are building without knowing exactly what they're doing. They'll probably run it with high gain mode with high voltage signal input.
The chip was a king a 'century' ago where no general purpose amplifiers were available. Of course, it could be used for building a LM386 radio or basic power amplifier at that age.
I haven't had much exposure to TDA2822M, but recently it proved me that it affects the audio quality(suppose headphone operation) by severe background hiss(in-born phenomena). Apart from that I like this chip because it's min. supply requirement is 1.8V and bridge configuration for high power mono operation.
For all my low voltage audio applications, I use TA7368P Toshiba amplifier which is quite decent in operation considering all these facts. It's min. supply voltage is 2V. TDA7052 also a good one so use it for direct replacement for LM386!
Anyway I use LM386 for experiments because it is a basic amplifier with in-built pre-amp so I could eliminate 1 or 2 discrete stages..a good chip for experiments!
Nowadays we're talking and dealing with quality and perfection..
OK, few questions..
Now what century we're in? - 21st century
Before 2001, which was the century? - 20th century.
Bit of calculations:
21 century - 20 century = 1 century.
So 20th century is 1(a) century ago.
Was LM386 present in 20th century? - Yes!
Was it a king? - The 'classic' LM386 was a 'audioking' during 80's. Some of you may find the attached document interesting.View attachment 40870
Which are all the audio chips present during 1975-80's?
That clearly proves it.
Did you notice the single quotes I put for 'century' in post #6?Well that would be in the last century ... a century ago means 100 yrs ago
I can't even believe that during 80's itself there were quite a number of better audio chips that beats LM386 on the same range?And I believe there were indeed better audio chips in the 80s... that does not, however, mean they were readily available at trash shack to the hobbyist.
certainly... the damnable L293 stepper chips are a testament to web exaggeration. hobbyists latch onto something and next thing you know that is all you find on generic searches!Did you notice the single quotes I put for 'century' in post #6?
So I feel it shame that still it holds the same attraction.
I assume two reasons for that:
1) Only because of popularity and exaggerated contents on web..
2) Availability.
