Hi all,
I need to record changes of voltage in a circuit over time. I need to record this for days at a time in an analysable format.
The voltage will only change in known jumps (probably no more than 6-8 values) and usually for short times only (milli seconds to seconds) between 0 and +12V.
So I figured maybe an LM 3914 would dothe job, if I could drive a tone generator and I pipe the output into the microphone input of a laptop. I could then simply record the "music" in a low resolution wave file format. as an aside, has someone got a suggestion for a particularly efficient codec?
Anyway, I'm no electronics expert at all, but handy with a circuit diagram, a multi meter and a soldering iron![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
How would I change the pitch of a tone generator (and what kind to use) from the output of the LED Voltmeter using the LM 3914 in dot mode?
Maybe there is a way of making a tone generator voltage dependent directly?
Is there a better way to go?
Any help will be greatly appreciated!
