LM567 help need
aruna1
Hi
I'm working on a tone decoder for my ultrasonic receiver. my goal is to detect input signal and verify whether its 40kHz. I'm using LM567chip for this. circuit is tuned for 40kHz and measured at pin 5.
my problem is circuit isn't working as it should be (according to data sheet)
please note in following diagrams C4 should be 0.02uF. I have incorrectly marked it as 0.001uF.
First attempt
This is the first circuit I tried
In this circuit LED does not light for the 40khz input signal. actually LED wont turn on what ever input it get.
Second attempt
Then my second attempt is disconnecting capacitor C1 from pin 1. then LED turned on dimly when there is no input and LED lights brightly when detecting 40kHz signal. this is the circuit
Third attempt
in my third attempt I connected 100k resistor from 5V to pin 1. after that LED is turned off when there is no 40khz input and LED turns on when detecting 40khz signal. but problem is now circuit responds to sounds other than 40khz signal.sounds like clapping and tapping sounds. when clapping LED blinks faintly.
here is the circuit
Forth attempt
here I connected both C1 and R3 as in data sheet but result is same as attempt 1. LED doesn't turn on with or without signal
this is the circuit
This is kind a funny. I cant figure out what the heck is wrong. first I thought LM567 was burned so I brought another but results are same.
can someone help me here? I'm pretty frustrated. ??? :p
thank you
Look at this image, your C! 0f 0.02uF gives a freq of ~4.5KHz with a 10K.
Try a 0.002uF cap.
Hi
I used a 10k potentiometer and adjusted it to give 40khz with 0.02uf capacitor. I gues resistance now is 1136 ohm
OK,
So what are the details of Vin, sine/square amplitude... etc.?
thank you very much
Found the last one.!
Built the circuit from the datasheet, the one I posted, I had to use a 22nF, thats 0.022uF thats the closest I have.
It works OK, thru a range of100mV thru 200mV, square and sine wave.
Nominal fo= 40.4KHz ........ BW ~ 38KHz to 44KHz
EDIT:
I am using a 20turn 10Kpot, if you are using a single pot you may find the adjustment too coarse.
EDIT:
hi I tried again but doesnt work.
weird
weird
Its working by my side on the bench, I have left it running.
Did you make the circuit I posted from the datasheet.???
Can you post a picture so that I can see your circuit layout.
circuit contains 3 ICs.
left top ic is TLC272 it is for amplifying input signal from ultrasonic receiver (gain 40) . then it is fed to LM567 (right top IC)
bottom IC is LM358 it is used as a comparator for a LDR circuit.
sorry for the low quality images. my cam is very old :)
now I'm using circuit with no capacitor at pin 1. this way circuit works but with drawback of responding to other sounds like clapping etc.
OK, I will down load and look at them.
Are you sure that the 40KHz source is emitting sound at 40kHz.???
EDIT:
Check that you are not over driving the LM567 with that pre amp OPA, if you over drive the LM567 it will give unpredictable results
I guess. at least that's what my multimeter shows. 40.23kHz
EDIT:
what do you mean by overdrive?
output of op amp is below 200mV.
as I said circuit works without cap at pin 1 of lm567
Whats that Green wire, from the picture it looks like its going to pin #8..??? 0V is pin #7.
You should have a 20nF on pin #1 to 0V not that 120K to +V.
Also check the back of the pcb for shorts and uncut track.
hi
green wire is : well I use second half of LM358 as a comparator to the output of LM567. so green wire is from pin 8 of LM567 to inverting input of LM358.nothing to worry their i guess.
about 120k. well in datasheet it says adding 130k resistor between pin 1 and supply will set minimum threshold of sensitivity to 10mV. so 120k is for that.
If I connect 20nf to pin 1 and ground circuit stops responding
hi
Show me how the L358 is connected to pin 8 of the LM567.
Your original diagrams did not show a LM358 connected.
hi
LM567 circuit doesnt work even without connecting the LM358. connecting LM358 comparator didnt change anything.
anyway here is the diagram.
hi
You should not connect the output of the LM567 directly into the NI of a LM358.
Its likely that the LM567 and/or the LM358 are damaged.
I will post a diagram.
