CorySCline
Hello all!
I am using the LME49811TB to build a large stage amplifier. the issue I'm running into is the power supply problem. I have done a few hours of research to no avail, so I will ask for an answer from knowledgable people
. The chip is labeled as a High Fidelity 200 Volt Power Amplifier. However, the **broken link removed**shows "Wide operating voltage range ±20V to ±100V".
2 Questions are present:
1) What are the actual voltage requirements?
2) How do I go about designing a power supply?
In reference to question 2: I have discovered that I need 2 capacitors, a transformer, and a bridge rectifier. How do I pick these out?
