Lms adaptive filter using dspic33f code error
ransiluj
Hello everyone,
I'm using dspic33fj128gp802 to background noise cancellation project. What i did was i'm taking the input from a microphone(headphone mic) as my input(In[]) and I'm giving my desire input by delaying some miliseconds then i have built a neural network using weights and updating weights. I tried this using simulink in matlab and it worked really well.
I checked this in lab and it didn't work. Then i gave Y=X in the coding and checked whether my circuit is working. It worked. So i realize it is a problem of my coding. This is a LMS adaptive filter and please help me if there is anything wrong in my code. I have uploaded all my files. I have used mplab and c30 compiler. This is a big help.
thank you
  • test2.zip
#include "p33fxxxx.h"
#include "dsp.h"
#include "..\h\adcdacDrv.h"
#include <math.h>
#include <libpic30.h>
//contants
#define beta 0.01 //convergence rate
#define N 31 //order of filter
#define NS 40 //number of samples
//#define Fs 8000 //sampling frequency
#define pi 3.1415926
//Macros for Configuration Fuse Registers:
//Invoke macros to set up  device configuration fuse registers.
//The fuses will select the oscillator source, power-up timers, watch-dog
//timers etc. The macros are defined within the device
//header files. The configuration fuse registers reside in Flash memory.
// Internal FRC Oscillator
_FOSCSEL(FNOSC_FRC);                            // FRC Oscillator
_FOSC(FCKSM_CSECMD & OSCIOFNC_ON  & POSCMD_NONE);
                                                // Clock Switching is enabled and Fail Safe Clock Monitor is disabled
                                                // OSC2 Pin Function: OSC2 is Clock Output
                                                // Primary Oscillator Mode: Disabled
_FWDT(FWDTEN_OFF);                              // Watchdog Timer Enabled/disabled by user software
                                                // (LPRC can be disabled by clearing SWDTEN bit in RCON register
//void measuring_y(unsigned int value_y);
int main (void)
    // Configure Oscillator to operate the device at 40MIPS
    // Fosc= Fin*M/(N1*N2), Fcy=Fosc/2
    // Fosc= 7.37M*43/(2*2)=79.22Mhz for ~40MIPS input clock
    PLLFBD=41;                                    // M=43
    CLKDIVbits.PLLPOST=0;                        // N1=2
    CLKDIVbits.PLLPRE=0;                        // N2=2
    OSCTUN=0;                                    // Tune FRC oscillator, if FRC is used
    // Disable Watch Dog Timer
    RCONbits.SWDTEN=0;
    // Clock switch to incorporate PLL
    __builtin_write_OSCCONH(0x01);                // Initiate Clock Switch to
                                                // FRC with PLL (NOSC=0b001)
    __builtin_write_OSCCONL(0x01);                // Start clock switching
    while (OSCCONbits.COSC != 0b001);            // Wait for Clock switch to occur
    // Wait for PLL to lock
    while(OSCCONbits.LOCK!=1) {};
      initAdc();                                  // Initialize the A/D converter to convert Channel 4
    initDac();                                    // Initialize the D/A converter
    initDma0();                                    // Initialize the DMA controller to buffer ADC data in conversion order
    initTmr3();                                    // Initialize the Timer to generate sampling event for ADC
    extern fractional BufferA[NUMSAMP];            // Ping pong buffer A
    extern fractional BufferB[NUMSAMP];            // Ping pong buffer B
    extern unsigned int DmaBuffer;                // DMA flag
    extern int flag;                            // Flag
    int i;
    double X;
    double Y;
    //float W0,W1=0,W2=0;
        //float a1 = -0.53195317487280547; //Coefficients
        //float a2 =  0.98711627632416965;
        //float b0 =  0.99355813816208483;
      //float b1 = -0.53195317487280547;
        //float b2 =  0.99355813816208483;
    long j;
    long t;
    double D;
    double E;
    double W[N+1] = {0.0};
    double In[N+1] = {0.0};
    while (1)                                  // Loop Endlessly - Execution is interrupt driven
        if(flag)
            for(i = 0; i < NUMSAMP; i++)
                while(DAC1STATbits.REMPTY != 1);// Wait for D/A conversion
                if(DmaBuffer == 0){
                    X = (BufferA[i]);
                  for (t = 0; t < NS; t++) //start adaptive algorithm
                            In[0] = X; //new noise sample (**from port B**)
                            //__delay_ms(100);
                            __delay32(100);
                            D = X; //desired signal (**delay and give from port B**)
                            Y = 0; //filter’output set to zero (output from port D)
                            for (j = 0; j <= N; j++)
                                Y = Y +(W[j] * In[j]); //calculate filter output(equation in research note)
                                E = D - Y; //calculate error signal(error output is not needed)
                                    for (j = N; j >= 0; j--)
                                        W[j] = W[j] + (beta*E*In[j]); //(updating filter coe. as in the equ. )
                                        if (j != 0)
                                        In[j] = In[j-1]; //update data sample
                    //W0 = (X) - (a1*W1) - (a2*W2);
                    //Y = (b0*W0) + (b1*W1) + (b2*W2);
                    DAC1RDAT = Y;                // Load the DAC buffer with data
                    //W2 = W1;
                    //W1 = W0;
                else{
                    X = (BufferB[i]);
                            //__delay_ms(100);
                            __delay32(100);
                                Y = Y + (W[j]* In[j]); //calculate filter output(equation in research note)
                                        if (j != 0)
                    //W2 = W1;
                    //W1 = W0;
            flag = 0;
    return 0;
