I wanted to use a rotary for ease of use, most of the time the intended use will not be for amplifiers and then only for short intervals and only for a speaker load and not at full output power.
No, I will not be switching with circuit active. It is simply a static load.
Should I be using ceramic power resistors then?
Is the wiring layout correct? It is modified form someone else's schematic
I made a audio load unit for testing audio amplifiers a few years ago. I used load resistors similar to these, except I used combinations of 16 ohm units.
It makes no difference, they are still wirewound, however, I would suggest you try measuring their inductance - for audio frequencies, particularly at lower frequencies, the inductance is rarely a problem. Not to mention, finding non-inductive high power resistors is going to be difficult, and incredibly expensive.
Edit: I just tested a 1 ohm 7W wirewound resistor, and it reads 1uH at 200KHz. This would only be 0.13 ohms at 20KHz.
What you don't want to do, it use them for radio frequency loads![]()
No, just a temporary protection load for circuit testing and a dummy speaker load for occasional (rare) tube amp protection load.What you don't want to do, it use them for radio frequency loads
Wirewound would be perfectly fine then, and considerably cheaper than non-inductive ones.No, just a temporary protection load for circuit testing and a dummy speaker load for occasional (rare) tube amp protection load.
Thanks for all the guidance and info
