looking for datasheet -- WT7514L
It is a supervisory circuit only as per the website indicated by you. it will help reduce component count in smps design-- but by itself it can't work as a SMPS controller as i understand from the data.
That is about the worst datasheet I have seen.
Thanks for replies. I will try sending them an email requesting a full datasheet; I'm not too confident of a reply -- but we'll see !!
Best regards.
Search Results
WT7514L
http://www.weltrend.com/product/power/wt7514l.htm
Half-bridge power supply supervisor with pulse-width-modulation(PWM).
3.3V/5V/12V UVP and OVP check.
CR6505 DIP-16 Half-bridge Power Supply Supervisor with PWM.
3.3V/5V/12V UVP and OVP Check. £¨ Compatible with WT7514 £©
CR6505 DIP-16 WT7514 AT2005
  • cr6505.pdf
Thanks very much for that, I now have something to work with. I certainly wasn't able to find the pin diagram when I tried searching.
Thanks and regards..
