Looking for lecture for plus null minus system [solved]
Grossel
Hi forum.
I do not know the correct english term for the subject (maybe not the greatest way to start off a thread).
I want to get a push in right direction where I can learn about theory about null/plus/minus (system ?) in 3 phase systems? Any teaching book/course you recommend?
Thanks in advance
Sorry, but I have never heard that expression before.
What does it do?
I was afraid of that - it is fully possible that it cannot be directly translated into english. What I do know is that it is a way of simplifying a 3 phase system before or while doing calculations.
Sorry, that rings no bells with me.
I'm not sure what you mean either. Are you referring to a so-called 'modified sine wave', such as used in many inverter circuits and where the waveform is +V, 0, -V, 0, +V, 0, -V ..... ?
Thanks for trying to help. If I do find an english terminology for this, I'll try to find this post and reply :cool:
I also do know this - from years back at school: Student that doesn't study specific for electrical engineering (3 phase system / power grid theory) here won't normally touch this topic. I assume that is the same for most other countrys as well.
Thanks dknguyen, but it is not the per-unit analysis I'm looking for. That is btw pretty much the same in norwegian anyway.
My biggest problem here is that Google doesn't give any sensible returns when I do search for "null system" "plus system" "minus system". So I'm actually completely stuck as to be enable to provide enough info so that any one probably would know what I ask for. The poor results from Google searches indicates for me that the topic is named something fundamentally different in english.
I do beleive (but have never learn in school) that "nul system" is when in a three phase system, one phase is considered as one phase system where neutral is threated as ground. That is a guess.
Is this what you're looking for?
Yes, but perhaps the general analysis method could be used in other disciplines?
Thank you, but no - that paper is for oil/seismic only.
Eureka - At last I found what it is named on english: symmetrical components fault analysis - that it is :woot:
Hmmm...
Maybe I have led a sheltered life, but I have never heard of it.:(
In 3 phase system symmetrical component analysis, fault currents are separated into three components: positive sequence, zero sequence, and negative sequence. Those were the 3 terms Grossel was having trouble finding the translations for. The positive sequence current has the same phase rotation as the power system. The negative sequence currents have a phase rotation in the opposite direction, and the zero sequence have no phase rotation at all.
