I made a design where I wanted to make a voltage buffer with a very low voltage offset (Vcc to output).
I looked up the types of voltage buffers and then got a rail-to-rail buffer with a low voltage bias, but it still has troubles giving an output close to Vcc.
Currently I would like to power the IC with 5V and get 5V out.
The chip im using now (LMX324ASD+)gives 4.95V out, which is acceptable but I would prefer <0.1V drop.
Is there a certain type of buffer that I can use to get around this? or do I have to make a fancy active circuit?
IC URL: **broken link removed**
