Hello.
I have a 12ga copper wire with two amps current. Voltage is approx 12v. Current is sometimes ac, sometimes dc. Rubber cladding around the wire increases the total cable diameter to approx 8cm.
I'd like to find a noncontact method of switching a relay on when the current is present in this wire, and switch off when current is not. I've so far only identified the following,
https://www.electro-tech-online.com/custompdfs/2008/11/3245.pdf
and in application notes at the Allegro website they describe the use of a flux concentrating ring to use these devices for low amperage. I need this sensor to be clamp on, so I'm looking at split core rings. I'll probably just have to saw one in half.
It only needs to operate a switch/relay and further accuracy is unimportant. All I need is signal to switch a relay when this approx 2amp +/-1.0 amp threshold is made (current running through the measured wire). The unit above has an onboard transistor cabable of switching a signal level relay. That works for me.
Basic idea looks simple enough in the spec sheets and application notes. Does this need any further signal conditioning to make use of its ability to sense ac or dc? Should I just order one of these hall sensors, a ferrite ring with an 8mm hole, and just start experimenting? I'd have to cut the ring in half, shave a gap sufficient to epoxy in the sensor, and then clamp the thing onto my cable. Is bigger better with the ferrite ring? How do I set the switch point and release point of this IC?
I need to make this from scratch with parts out of digikey, mouser, et al. This isn't a homework assignment. It's just that I need to keep the total parts cost below about 15USD or this won't be practical.
Advice would be heavenly!
