I need good current sensor IC. I'm going to measure current change of the PC when software is running. Do you have an idea about how much current should it take. I mean the current that is changing. Using a good accurate IC is good way to measure that change of the current ? IC like ACS 712 is good or bad?
or is there any current sensing IC for measure micro current change or mA change?
and you can tell me what is most accurate way to measure the current.
1.using hall sensor
2.using a current sensing resistor.
what is the most appropriate way?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
1.using hall sensor
