Of course you can, if you don't mind its idle current of up to 10mA all the time.SO I cant use LM317?
I have never used a low current adjustable regulator.what are examples of low current low voltage regulators available?
Maybe time to upgarde again or are you running DOS 6?I upgraded the 486/66MHz processor in my old pc to a 486/100MHz....
What voltage are you starting with (the input voltage)? Is it a battery? if so, what size or type?hi,
I just want to ask of any 3V voltage regulator that could run an IC with the rated voltage of 3.0V-3.6V and current of 3-4mA (6.5uA in sleepmode).
Will LM317 work, particularly when in sleepmode? Is there any maintaining load current to watch out for?
thanks,
Ace
