But what will you use to switch 10 amps at 120V? We are talking AC mains voltage here, aren't we?zener said:the voltage should come back on at 112v.I would rather not use a relay,trying to keep it as small as possible.It seems to me,there should be a low voltage sensing IC.
zener
How many cycles below 90V do you want to have before you cut off power?zener said:Yes ,we are switching 120vac.I haven't thought this whole thing out I'm just starting. possibly i can use a thyristor to switch it.the sensing circuit can be low voltage useing a rectifier.the gap is switching the thyristor.any ideas will be appreciated.
zener
That's approximate, I hope. About 10 seconds, then?zener said:600 cycles
