Hi I,No! The LVP is a wondrous idea! You can use the same system voltage to program the device. However... Once a device is set to Low Voltage Programming.. RE3 is then unavailable as a IO pin...
Ok, thanks.In your case... Just make sure LVP is off in the config and don't pay it any mind... You'll never use it!
Just do it as you would before... And Yes! as you say.. Make sure pickit3 is set for 3v3...
???See attached?
Yes, new computer!
Hi,You are trying to save to a directory that you're not allowed to....
You need to download hoversnap.... This lets you snapshot parts of the screen...
