I have a motor on a table saw I purchased. It has an old electrical wire with a switch in the wire and I want to change the switch and wire which appears to have come from an electric blanket but when I opened the the housing on the motor I found it could be set up for low voltage or high voltage
1. What is the difference.
Low is
P1 - UNGR D LINE
P2, T8, T3 - Tape
T2, T5, T4 - Line
High is
P1 - UNGR D LINE
P2 - Tape
T8, T3, T2 - Tape
T5, T4 - Line
2. What do teh wrods "tape" and "line mean?
3. I am using in my garage standard 120 which do I want?
This one appears to be wired for high.
Three wires come out of the wire
A green that is attached to screw
A black that is attached to a breaker/reset switch
A white that is connected to Three wires
4. Where would be the best place to install a switch, in the wire to or somewher else?
4. What kind of switch should I use.
I know this is a lot of questions but any help anyoen could give would be greatly appreciated.
Low is
P1 - UNGR D LINE
P2, T8, T3 - Tape
T2, T5, T4 - Line
High is
P1 - UNGR D LINE
P2 - Tape
T8, T3, T2 - Tape
T5, T4 - Line
