LPC 2148 Serial Communication
Hi.. I've written a code to transmit a character to PC using UART0. But, however, the hyperterminal is blank.
Why is this happening?
My code is as follows:
#include "LPC214x.h"
void init(void);
int main()
{ int i=0;
init();
while(i<=10){
U1THR='D';
while(!(U1LSR && 0x60));
i++;
void init()
PINSEL0=0x00050005;
U1FCR=0x07; //enable and clear FIFOs
U1LCR=0x83; //8-N-1, enable divisors
U1DLL=0x62; //9600 baud (9615)
U1DLM=0x00;
U1LCR=0x03; //8-N-1, disable divisors
But if I modify d same code for UART1 it works fine.. Its only giving a problem with UART0..
Is this happening because I'm using UART0 as ISP port to program my chip? I use flash magic & use the DTR & RTS to control the RST & ISP pins. So is it possible that my port is stuck in ISP mode & is that the reason why its not functioning as a normal UART?
I'm really confused..
how to use uart interrupt in lpc2148?
how to receive char through interrupt in lpc2148?tell me what is wrong in this code.received char i've to transmit again but it is not working.
#include <lpc214x.h>
void init_UART0(void)
VPBDIV=0x01;
PINSEL0|=(1<<0)|(1<<2);
U0LCR=0x83;
/*to set baudrate using formula, load below registers
U0DLL=78;
U0FDR=0x28;
U0LCR=0x03;
U0IER=0x01;
VICIntSelect=0x00;//IRQ interrupt
VICVectAddr0=(unsigned long)UART0_isr;//isr assigned to 0th slot
VICVectCntl0=0x26;//vector interrupt enable & UART0 select
VICIntEnable=(1<<6);//enable interrupt
void Transmit(unsigned char ch)
while(!(U0LSR & 0x20)); //check THO is empty or not
U0THR=ch;
void UART0_isr(void)__irq
unsigned char p;
p=U0RBR;
Transmit(p);
VICVectAddr0=0x00;//clear address register
int main()
init_UART0();
while(1);
it seems that your code is correct . if you are using P0.1 for ISP programing, you must remove the pull up resistor on this pin.
