If I am reading the data sheet correctly the pnp transistor limits the charge current in the fast charge mode by the value of the resistor from the program pin 7 to ground. In this case 1A.Hi,
i don't understand wat exactly purpose and function using pnp transistor(FZT948) attach to ltc4060 here. Any1 can help me try to explain to me...@@"
thx~
The PNP appears to be the only charge path for the battery. It is off-chip because it dissipates too much power to be on-chip (not to mention the problems with making a high-quality PNP on-chip with the process being used).Hi,
thx~
