LTSpice - Digital - Pulse Generator on Edge? (monostable)
ACharnley
Is there an out-the-box digital control that'll do it?
I can generate using components but want to keep it clean with a single digital control if possible (better replication of the MCU which will be doing it in software).
Is this what you are trying to do ?
The above also allows you to control the pulse width generated at output.
Or is this -
What is the rate at the input, latency to output, and output pulse width range you want ?
Regards, Dana.
Hi
There is no pre-made leading edge detector in LTspice.
but you can make one like this:
The two schmitt buffer devices provide input hysteresis for the AND device
The inverter "delay" device sets the pulse width using the Td parameter.
A trailing edge detector:
Brill will try that in an hour. Currently doing it as the attached. Works fine but want to keep to digital representation.
