LTspice queries
alec_t
Most Helpful Member
1) If I draw a schematic where the only transistor type is a default NPN bjt, the auto-generated netlist includes the lines
.model NPN NPN
.model PNP PNP
Why does LTS feel the need to add the apparently spurious reference to PNP?
2) I have a model defined in a .sub file. A transient analysis in a sim using the model converges providing I use the global directive '.options gmin=1e-8'. I would like to add this gmin limitation to the model file itself, rather than have to apply it globally, but the .options directive is ignored if within the file. Is there a workaround?
.model NPN NPN
.model PNP PNP
These are not spurious references.
The .model syntax is:
.model <modelname> <type> (params)
"modelname" can be any name you assign to the component but must be unique, and it is assigned to the "value" attribute of the symbol. It is used to "lookup" the model definition.
"type" is the name of the spice defined component type, such as NPN, PNP, SW or any of the supported component types.
For the example you've shown, the first NPN is the modelname, the second NPN is the model type and is the default definition for an NPN transistor. So any transistor with a "modelname"
of "NPN will be associated with the NPN model definition.
The option statement is a transient analysis directive, so it can only be placed outside of the .subckt definition.
Thanks. I fully understand the NPN reference, but that wasn't what I was asking about. Why the PNP reference when the circuit contains no PNP device?
That was what I found. Is there a workaround to enable gmin to be set within the definition, i.e to make gmin a local parameter rather than global?
I tried duplicating that behavior on my system but it doesn't place "spurious" references.
Are you using the latest version?
It can't be placed in a subcircuit definition, its a simulation directive.
You can place it outside the subcircuit def with other sim options...
Example:
.subckt opamp 1 2 3
.ends opamp
.options gmin=1e-10
.end
But I don't recommend it...
eT
I tried duplicating that behavior on my system but it doesn't place "spurious" references. Are you using the latest version?
Strange. Yes, latest version.
Here's a simple .asc. If you run it and go to View/Netlist you will see that a non-existent PNP gets referenced.
  • Draft13.asc
Ok...I must have missed it when I tried the first time....but it seems to be adding it now.
All I did was open a new schematic, added an NPN, then viewed the netlist. Both models showed up.
And it doesn't matter if you add an NPN or PNP, it adds both models. o_O
Very odd...:confused:
eT
Ok...I found out what causes this to happen
Goto:
Control Panel->Netlist Options->Semiconductor Models
Default Devices[*] <---uncheck this, it will keep it from adding the default models
but if you add a transistor with a model name of NPN or PNP
it will produce error. So you either have to "Pick New Transistor"
from the menu, define an "NPN" or "PNP" .model on the
on the schematic, or use a .subcircuit file.
Default Libraries[*] <---leave this checked so it can use the existing libraries
eT
Thanks for the info.
