LTspice simulation of behavioural voltage sources
desan2012
Hi everyone,
I am using LTSpice IV version 4.231.
I have a polynomial fit to a current-voltage characteristic curve and would like to simulate in LTSpice using B sources.
The polynomial fit is:
Appreciate your suggestions and comments.
Welcome to ETO!
Set the bv source value to V=05407*i(n)**5+4.8027*i(n)**4 etc, where n is the identifier of the component in which current x flows.
many thanks alec_t.
Do I place the identifier 'n' on the schematic?
The equation is a polynomial fit for the I-V characteristics of a photovoltaic cell.
I carried out a couple of experiments in the lab and plotted the I-V curve at a specific irradiance.
Would 'n' therefore be Rs or Rp on the PV model?
I don't know what PV model you're using, but if you're interested in the Rs current then put Rs in place of n.
Here's an example with a LED and a bv source.
Are you saying that at a given irradiance,
the Voltage V from the panel = 0.5407*I**5 + 4.2807*I**4 + 14.649*I**3 + 16.603*I**2 + 8.4911*I + 261.88, where I is the Current output of the panel?
The attached .asc file is how to model that:
I1 is the independent variable of the simulation. The red trace shows the MPPT.
  • Draft36l.asc
Many thanks to alec_t and MikeMI.
My apologies for not getting back yesterday.
The PV equivalent circuit is the single diode model with Rs and Rsh.
My apologies for the misunderstanding. The equation is actually:
I=0.5407v^5+4.8027v^4+14.649v^3+16.603v^2-8.9411v+261.88
where I is the output current supplied by the PV cell and V is the voltage across it.
That would say that the short-circuit (V=0) panel current is 261.88A. I would like to see your panel ;)
The way I interpreted the equation is that the open-circuit (I=0) output voltage of the panel is 261V and per my plot, the short-circuit (v=0) output current of the panel is ~4.2A, which is more like real panels I have worked with.
Which is it?
Another misunderstanding. When V=0, the panel current is 261 uA (micro amperes).
For simplicity, the PV cell is the AM-1816CA. I am using it for indoor PV energy harvesting.
According to the spec, at 200 Lux you can harvest ~250uW. Doesn't seem much. What do you plan to do with the energy harvested?
The AM-1816CA can produce a short-circuit current of 261 uA for a light intensity of 500 lux incident on it.
The intended application is Internet-of-things. Looking into powering low-power sensors e.g. proximity, CO2, temperature, light level sensors.
Another misunderstanding. When V=0, the panel current is 261 uA (micro amperes)...
Units are important..., so are boundary conditions.
Here it is again:
  • Draft36v.asc
Appreciate the assistance MikeMI, alec_t and ronsimpson
Will keep in mind to always specify units and boundary conditions in the future.
Kind regards.
MikeMI, could you explain how you derived the spice equation. New to LTSpice.
Read in an article online that the polynomial fit curve needs to be converted to Laplace transform for use in LTSpice??
You are making it too hard. Read the Help file for
B. Arbitrary Behavioral Voltage or Current Sources.
and
.DC -- Perform a DC Source Sweep Analysis
