LTspice: Splitting a gate drive into two separate gate drive pulse streams?
Flyback
I wish to simulate a Half Bridge SMPS in LTspice, but using the LT1243 adapted to control it.
I need to split the gate drive in to two separate streams as in the attached.
Would you say D flip flop for each stream would be best to achieve these two streams?
  • LT1243 as half bridge driver.asc
Thanks Ronsimpson, the LTC3721 has slope compensation and a rather low current sense voltage reference, and takes longer to simulate.
The LT1243 is very simple and straightforward.
(I like the LTC3721 though and if i was doing it on the bench i would consider using it in some cases.)
The attached (LTspice and schem) shows how it can be done with the LT1243 …but I am getting an unfortunate little spike in the waveform streams as shown.
Any better ways?
  • LT1243 as half bridge driver 2.asc
Your little spike may be a sim artefact. Putting even 1pF in parallel with S1 or S2 increases the spike dramatically.
