HI:
If anyone is knowledgeable along these lines..... I have a device that uses a 6 volt 450mA adapter to recharge built-in rechargeable batteries, Is it better to go with a higher or lower mA capacity adapter if a 450mA is not available? I would have figured that more is better than not enough. The device will only draw what it normally needs? I you go with a lower mA model then there would not necessarily be enough current to charge in reasonable time period?
Knowledgeable feed-back appreciated very much!
DD
DD
