I want to build this mag timer http://www.rst-engr.com/kitplanes/KP9910/KP9910.htm , but I am not sure about the pin out for the LM324. The schematic does not number the pins for the LM324.
Thanks, sam
Thanks, sam
The datasheet has the pin numbers. What is your source of confusion?sam2 said:dch222 thanks for the info, but I have the data sheet and the box for the LM 324 has the pin out .
The schematic does not have the pins numberd for the LM 324. I am new to electronics and was wondering if I just missing somthing in the schematic.
Thanks ,sam
In other schematics I have seen that show the LM324, break it down into 4 separate triangular symbols, and then list the input/output numbers on each triangle (1-14).The schematics in the article dont show any of those numbers.Ron H said:The datasheet has the pin numbers. What is your source of confusion?
Here ya go. You can actually use any section for each of the 4 op amps in the schematic.sam2 said:In other schematics I have seen that show the LM324, break it down into 4 separate triangular symbols, and then list the input/output numbers on each triangle (1-14).The schematics in the article dont show any of those numbers.
Is this a mistake or is there somthing I am missing( like my brain)?
Thanks, sam
Edit: Or does it only matter that I keep the inputs and output together for each op amp? Like 1 together , 2 together.....3,4.
You reign supremesam2 said:Thanks Ron H, I do appreciate the help.
Trying to build stuff when you dont know how everything works is a bugger!
I am not worthy
I am not worthy
I am not worthy
sam
