thank for ur answer.. the above circuit i made many years ago . it really was bad for quality. But the knowledges i studies from the phenomenon occur within the circuit are very useful. do you explain the operation principle of the circuit?THe frequency will be slightly lower than predicted because of the parasitic capacitance.
No offence but this circuit is not very good quality.
The frequency should drop a little bit. If the frequency rises, then you are looking at an image and the real signal is probably 25.4 MHz away from the image (2 x 10.7 MHz).
So you can pick up higher frequencies because it interferes with the IF? That makes sense. <SOME TEXT REMOVED>.
if the circuit is FM transmitter...how about the varicap ? what is it in this circuit?T1 is just a common emitter amplifier which boosts the signal from the microphone.
T2 is the RF oscillator.
Oscillator wise, it's actually configured as a common base amplifier. At DC it's base is biased by T1's collector. At AC C4 connects T2's base to +V which as far as AC is concerned is the same as 0V. L1 and C6 form a tuned circuit and C5 provides some positive feedback to T2's emitter which serves as the input. The circuit behaves like an oscillator because of positive feedback, like when you hold the mic of connected to near to a speaker via an amplifier it oscillates at an audible frequency, creating a howling sound. In this case the circuit resonates at the frequency determined by the LC tuned circuit which should be in the FM band.
The circuit actually produces both AM and FM. The amplitude of the output signal will change as T2's base voltage is changed which alters its base and collector current and therefore its gain. The frequency is changed because the capacitance of TR2 is voltage dependant which changes the frequency of the tuned circuit.
Its not that it actually overloads the IF; if the receiver is a single conversion superhetrodyne, then two different frequencies can beat with the local oscillator to create the IF (intermediate frequency). The most common IF is 10.7 MHz, so one frequency 10.7 above the local oscillator frequency and another frequency 10.7 MHz below the local oscillator frequency will both produce an output centered at 10.7 MHz. The tuning of the first stage is supposed to suppress the unwanted frequency.
(Remembered this in the shower) Also, I have noted that in cheap FM receivers with digital synthesizers, for reasons that are not entirely clear, a clean oscillator at a single frequency frequency will show up on several spots on the dial. This might be the result of the receiver being all on one chip and the reference for the synthesizer and its harmonics get into the wrong places on the chip. Its best to not use cheap digital tuning receivers that have digital tuning while turning in your transmitter.
you mean Ccb capacitor of transitor is the varicap , if like this, the resonation freq is L(C+Ccb) ?As already explained, the circuit produces both AM and FM modulation, no need for a varicap, it relies on changes in capacitnace inside the transistor.
Yes, that's how it works.
The AM can be removed by AC coupling the LC tank to T1, I've never tried it, it's just an idea.
I've also removed a couple of capacitors I don't think are needed.
Sorry, absolutely terrible idea - give it a little thought and you'll see why!.
You are wrong, and the circuit won't work - the one on the mike is just to help prevent RF entering that way (so not too critical) the one on the base of the oscillator is absolutely essential, it's that component that makes it a common base circuit.
